RCU Forums - View Single Post - 4 Star 60 Pushrod Conversion...
Old 10-17-2005 | 04:37 AM
Sukhoi_Madness's Avatar
Sukhoi_Madness
Default RE: 4 Star 60 Pushrod Conversion...
ORIGINAL: fred123
Can't understand why you don't like the flex cable system.. I have one on a 4*60, a something extra, a Hog Bipe and a 1/5 scale cub.. never had the slightest problem with either. Did cut a sleeve too short on one, and simply slid a short section of sleeve over the cable to stiffen it between where I cut it off and the throttle arm, leaving enough gap to handle the required throw... Worked fine..Fred123[&:]
They may have changed wire used since you built yours...
It could just be me, but I found the wire to be a piece of crap which would never have worked even if I did not make the mistake with the outer tube...
It is my first kit so I don't have much experience to go on...
The point of this post is to demo the mod though... Not rip on the wire system...
Matt
