RE: My Edge 540T Rolls with full elevator application
ive got a seagull edge 540 120 size 78" wing that was an absolute pig to get off the ground never consistent flying , snappy and pitch sensitive,manual said 110 -120 mm from leading edge. when i worked it out mathimatically on the half wing span it worked out at 40% set it to 27% or 85 mm it become a real honey had to remove to down thrust and had changed incidences as well all to no avail. it was the manual,even with a zenoah 38 up front it will snap if pushed but flys like it should now,does seem to bother about the weight as much as i had expected
