RCU Forums - View Single Post - Crank Case Vent
Thread
Crank Case Vent
10-17-2005 | 09:48 AM
18
William Robison
My Feedback: (
3
Nov 2002
20,205
Mary Esther, Florida, FL
RE: Crank Case Vent
Waco:
Quote:
..glad to see that your crystal ball is working...
No Crystal ball needed. As I said, and is obvious, every bit of fresh oil going into the engine flows past the inlet valve seat. If you want more oil in the intake valve use a higher percentage oil in your fuel. Simple.
I have never, even in the highest time Saito engines (or OS for that matter), seen a model engine valve worn to the extent you mentioned in your 50 hour OS. Since I have an OS brand crystal ball with a blown transistor I can't be sure, but I think an inlet air filter would help you more than additional oil.
So why haven't I fixed my crystal ball? OS wants too much money for the replacement part.
Hobbsy:
This is ALL on topic. Exhaust emissions are a hot subject. As stated in another thread California has already outlawed two stroke engines in lawn equipment, they're probably putting the eyeball on model engines as we speak.
Bill.
Reply
Like
William Robison
View Public Profile
Send a private message to William Robison
Find More Posts by William Robison
View iTrader Profile
