RCU Forums - View Single Post - Robbe SeaWolf
Old 10-17-2005 | 10:46 AM
  #70
periscope's Avatar
periscope
Default RE: Robbe SeaWolf
Hi SJN - I supose you'll be getting pretty fed up with answering questions on the Seawolf soon, but if I could just pester you with a couple. I've just bought the V2 this weekend and will be starting with it soon but can you explain why the V2 has the hole in the front - I think perhaps it has something to do with making it easier to get into the electrics but perhaps I have misunderstood it - also am I right in thinking that to get into the watertight compartment four screws only have to be removed so that the tail end can slide out to get to the battery for charging. If it is fairly easy to get into I was wondering about not using the receiver switch extension out at the rear. I'd appreciate any help you could give me on this.
Many thanks,
Ian
