your welcome.
it takes 2 seconds to get into the WTC, so I jus installed my switch inside. Besides, after every run, I want to see if there is any water in it anyway
One thing I have done differnetly is the forward hull section. I have glued mine together because I could not get a good fit.......built it too quickly
It does make balancing a little dufficult when you have to install lead balast there. Also, if something ever goes wrong with the WTC bolt in there, I will be in trouble too :-)
Just build it exacly as the poor instructions say, and you wil be fine [sm=thumbup.gif]
