ORIGINAL: rcbill
Thanks for the help so far. I do have a couple more questions. Should the engine four stroke from being rich while being broke in?? I know the fuel/air mix is rich - but is that too rich?? Also I know the tank should be pumped out at the end of the day but should the engine carburator be run dry also. Should the carburator be kept dry during winter storage?? Once again any info would be appreciated.
THe DA 50 won't "four stroke" as the ignition fires it each stroke. If you run it too rich it will complain at you. Just run it a tad rich with a tad more oil.
