ORIGINAL: roxyboby
hi everybody. all of a sudden I have to increase the aileron trim on my Hitech lazer6 transmitter to the left quiet a bit. What do u think the problem could be. Does it mean that the motor on the right is going bad !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hello,
I have experienced the same problem few days ago. The cage inside the right motor (for my issue it was the right motor !) has felt down after a little crash then the motor receive no fresh air from the outside and reach very high temperature et decrease its efficiency with the consequence that I had to trim too much to the left.
I don't know if your problem is the same, but I hope you could solve it .
