RCU Forums - View Single Post - Prop Adapter Set Screw Problem
Old 10-18-2005 | 11:39 AM
RK-Aircraft
My Feedback: (81)
Default RE: Prop Adapter Set Screw Problem
I do two things. Use a dremel to grind a flat spot were the set screw hits the shaft AND a drop of thread lock (the blue stuff) on screw thread to keep it tight. I have never had problems with that technique.
