RCU Forums - View Single Post - Need engine help!!
Old 10-18-2005 | 12:35 PM
sbd-5
Banned
Default RE: Need engine help!!
you may try to mount a strap to the old muffler and still use it.if vibration broke the ears off the muffler you better find out what is causing it before it does the same to your radio gear and airframe.ballance prop?loose mount?these engines do not vibrate the way you describe.by the way the 45 fsr uses the same crankase as the 40 fsr.
