RCU Forums - View Single Post - Trimming
Thread: Trimming
Old 10-18-2005 | 12:48 PM
kingaltair
Default RE: Trimming
ORIGINAL: impactiq
Now... pull plane into a inside loop. If the plane wants to turn in or out while doing this. One of two things are causing this. Either the rudder or elevator halves are not properly trimmed (set) to work with each other.(Just because your pitch gage tells you your elevators halves are aligned side to side one the ground.... does not mean they are in the air.) If the plane wants to turn out to the left, add left rudder trim. If the plane want to turn out to the right, add right trim. Correct as necessary so plane will track straight through out a inside loop. IF the plane does not turn out either way... with very little to no rudder input correction... you are ready for the next step.
Now... perform a outside loop once the above has been corrected. If the plane plane wants to turn out right or left, then the elevator halves are not aligned. In the event of turning out to the left, the left elevator is to low. If it turns out to the right, the right elevator half is to low.
At the risk of exposing my ignorance, I'm a little confused about the terms "turn in" and "turn out" during an inside loop---------which way is IN and which is OUT? Do you mean turn, (yaw) from the plane's perspective, and if so, why would it be corrected by giving MORE of the same, or do you mean introduce a rolling motion. Help me picture this
Another method I've been told to check for proper CG is by putting the plane in a gentle, (30 degree) climb, and see if it will maintain its heading without settling. If it wants to settle, it's nose heavy. Seems to work.
