RCU Forums - View Single Post - Are these servos enough
Old 10-18-2005 | 10:01 PM
STG's Avatar
STG
My Feedback: (26)
Default RE: Are these servos enough
ORIGINAL: Devin McGrath
Per instruction manual yes but many people believe that the Funtana needs to have much more than that. As for my Funtana it has about that with FMA direct metal gear digitals. I believe it is more important to have no slop linkages and good holding power on the servos. as long as you don't plan on ripping your Funtana through the sky at WOT then I wouldn't worry about it to much. Plus my Funtana is way over powered carrying 3.5 horse and I have not had a problem with flutter yet just watch your speed the Funtana does not need to be going fast to perform any aerobatic maneuver. The only thing I can say is that it could use just a little more on the rudder.
Photo taken by Greg Cardillo at the NEAT Fair 2005.
Funny thing is look at the H9 instruction manual for the Showtime 3D--they are recommending a lot more servo now.
If you set it up with true 3D rates and want to slam it around make sure you have MG servos with at least 90oz. (no minis)
My F90 will KE loop clockwise, but not counter clockwise. It is no where as strong on its side as the Yak or Fliton 330. It is a ton of fun to fly though and I don't mind going low with it. [sm=lol.gif]
