RE: Prop drilling guide orientation?
They way I understand it, there are two considerations. Since the grain of the wood runs along the length of the propeller, it's best not to have two holes along the same grain line (less chance of splitting). So the orientation you described would not be recommended.
Also you want to have a prop tip at around 2 o'clock with the engine at compression. That way you have the best chance of starting when you flip the prop over.
