RCU Forums - View Single Post - how to set thrust up.
Old 10-19-2005 | 06:54 AM
exeter_acres's Avatar
exeter_acres
Default RE: how to set thrust up.
which plane.....
are the the foamy and fun fly that you mentioned all that you have flown?? that could be a big step
usually I build that plan as the designer intended... I then fly it to see if it needs any thrust then adjust accordingly, shims or different size standoffs, etc. etc.
