ORIGINAL: bdavison
Greubin, The Blade starts to loose power when a lipo reaches 11.16V. Its normal. This is actually a good thing, because it makes you aware its time to recharge the battery. The Blade does not have a voltage cut-off, so you could technically run it down too low, but if your actually flying it, you will run out of available "flight" power long before it reaches the minimal 9.9V
Great info, thanks for the response
