RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 10-19-2005 | 06:47 PM
  #3511
GONE2THERIVER
Default RE: U-Can-Do 3d 46?
Well I had to take the metal gear servos back and get some futaba hi torque nylon gear servos to cure the problem. I tried a new reverser with same results. I also tried a different receiver same results. Antenna is external going up to the top of the rudder right out of the receiver.
I just don't know what to think other than the metal gears freak the reverser out!!!!
When you plug the metal gear servos into the receiver without the reverser they worked great..
I'll just take it as a lesson learned!!! No metal gears for me when using a reverser!!!
Someday hope to get a better radio where I can mix more stuff.
Thanks for the help anyway. You guys have cured many other problems. Can't get a homerun everytime!!! Have a good one!!
