RE: Gear Door Hinging Tips
I use .007 alu strips to line the edges so doors don't pull inside the fuse. Glue with goop. Cuts easier than Ployply with scissors and you can bend it to fit the door.
Also use those little rare-earth magnets on the front corner to keep the door shut tight.
