RCU Forums - View Single Post - Help with dual elevator servos
Old 10-20-2005 | 10:44 AM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Help with dual elevator servos
ORIGINAL: garcay
Yes it will affect performance. Get a servo synch. Its called a matchbox by JR: http://www.horizonhobby.com/Shop/ByC...ProdID=JRPA900
If your really looking for precision--then garacy is right on the money.
You could also get an Equalizer from www.smart-fly.com. Same thing as a Matchbox--but a little cheaper.
Are your control linkages both set up the same way? Same length on the pushrods? Control horns adjusted to match each other?
Just a few things to look for.
But, definetly, get a Matchbox if you can't work it out. It's the only way to get any precision out of a dual elevator setup when you don't have a radio that will mix it for you.
(editd four speling[:-])
