RE: Help with dual elevator servos
One stays centered and the pot "knows" which one to adjust to equalize the elevators.
The only problem I had with it at first was that the pot wants to wander a little as you put stuff in the fuse and button things up. So I drilled a small hole in the side of the fuse and centered the pot so I could make the adjustment with the wing on. Problem solved nicely.
