RE: Eny 46 prop?
Hello; I have two of those fine engines, the prop I had most sucess with is an old Taipan 11 x 7. The other engine has an old top flite 11 x7 wood prop on it. the Taipan prop has wide blades and I think is nylon, it is quite flexible. Is this a four stroke engine? Mine are.
If it is a two stroke, then I can't help you.
