RCU Forums - View Single Post - Help with dual elevator servos
Old 10-20-2005 | 02:02 PM
MannyEdge's Avatar
MannyEdge
My Feedback: (9)
Default RE: Help with dual elevator servos
Sorry to butt in, but I have a questioned about y-harness used for dual elevators. Can you use them and what is the difference between the y-harness and the reversing y-harness besides the obvious the reversing action? I have a Goldberg Tiger 2 and I have to used dual elevators because the dowel rod that connects the elevators halves got fueled soaked. So I split the elevators halves and ran a pushrod for the second elevator servo. The problem I have is there is no room in the tiger to have the servos pointing at each other to use the reversing y-harness so I opted to use the y-harness. What problems could I run into? The elevators halves seem to be moving the same distance, but it is hard to tell. Should I purchase this from [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXANF2&P=0]Futaba[/link]? I am using a 7CAP from futaba.
Thanks in advance!!
