Need HELP!!!!
Hi,
I had tried to fly my Trainer and busted the very end of the main wing off. I have purchased a new Leading edge for the main wing since 2 /12" is broke. My Questions are:
1) Can I use a hardwood L/E instead of Balsa which is the original?
2) The hardwood L/E I bought is slightly bigger then the original Balsa L/E, can I use this without having to make it the same size? I will be replacing both L/E's if I can use the new stuff.
Thanks very much in advance...
