RCU Forums - View Single Post - Centre of Gravity
Old 10-21-2005 | 07:50 AM
RK-Aircraft
My Feedback: (81)
Default RE: Centre of Gravity
Rod,
A bipe is balance on the top wing right side up. If you balance it upside down, there is too much weight over the top that would make it unstable. The reason the convention has you balancing high wings up and low wings down is because the fuse weight needs to be below the wing in both cases. I guess it doesn't matter when balancing mid-wings.
