RE: Id plane and plans
Does the leading edge of the wing use a hard wood dowl for shape???? If not then it is not a Jr Tigre. The Jr Tigre also had a real big clear canopy that shaped about 1/3 of the fuse. I thought the span was 50 inch?????
It sort of looks like a big version of a plan from RCM called Chipps or something close to that. Can you post a side view
Dru.
