RE: Welcome to Club SAITO !
Tim:
Still sounds like the top end (HS needle) is lean. The LS could be too, but if it idles nicely and answers the throttle cleanly it wont be too far lean.
As I said, iopen the HS a bit and try it, then a bit more, etc. If it wont go to full, and it's not blubbering, just about has to be lean. You might also check the fuel hoses and ports, be sure there's not some small bits or leaks there.
Bill.
