RCU Forums - View Single Post - Super Tigre 40 problems
Old 10-22-2005 | 06:47 AM
AMB
Default RE: Super Tigre 40 problems
Just a thought if you have more of them swap the carb, If that shows no improvement check the the cylinder is in the correct position and not rotated. I do not remember if they use a pin to keep in the right position or not. If a pinned liner thats not the problem
I assume your O ring is ok between carb and engine martin
