RE: .45 in a .21
Something I forgot to mention. You will learn way more about setting up a boat if you begin with a low powered engine than a high powered one. The low powered engine will force you to squeeze every possible bit you can out of the hull through proper tuning and trimming. Using an over powered engine allows you to be sloppy.
