RCU Forums - View Single Post - Need help from the covering pro's
Old 11-05-2002 | 09:48 PM
FLYBOY's Avatar
FLYBOY
Default Need help from the covering pro's
What I do even on arcs is cut thin, maybe 1/2 inch strips, short enough to make the bend, long as possible, and use thick CA to put them on intead of heat. Then I cover the surface, covering as much of the piece I used to do the corner as possible, without causing a bubble or kink. Seems to work well. No gaps and nothing comes loose later.
