RE: Extreme Flight 87" Yak 54 - Build & Fly
I see your point but I always hear how you should use as little subtrim or end point adj as you need to because you are decreasing the speed of one servo vs the other
I messed around a bit more with the linkage and I had to decrease the endpoint on 1 servo to 130 from 140..I can get 65deg up and 50 down and they are even thru out full travel
