RE: What are the differences?
Mechanical require the use of a retract servo. The other type use's air to make the gears go up and down and are activated by the use of a standard servo moving an arm on an air valve. Mechanical take more effort to get set up as they need to have pushrods fitted to them and it can be alot of work to get them correct. Good Luck, Dave
