Originally posted by GarryM
TerrellFlyer
I was wondering about using it to power a quick charger (charging rx and tx at the field) . Not sure whether the draw of a quick charger would generate too much heat if it was enclosed?
Garry
I use mine to run my quick charger and the only problem is the quick charger drains the supply battery quick.
I get about 5-6 charges (if that) on my ZAGI battery before its too weak to kick over my engine with the starter
it is great to use to quick charge your RX or TX packs if they get a little too low for comfort
