RE: Welcome to Club SAITO !
The ticking is normal.
This caused by the difference between the cam pushing the valves open to the point where the valves are trying to push the cam. The noise is generated by the lash in the gears between the cam shaft and the crankshaft when the lash transfers to the other side of the teeth on the gears.
