RE: DYI PROP ADAPTER HUBS
I use Loctite 620 I think it is. Have never had one come loose yet. I don't use any cross drilled set screws either. I use the prop bolted to the hub to install and tighten. I also use a piece of rope in the cylinder to hold the piston while I use the prop as a "T" wrench to tighten the hub.
