RE: Welcome to Club SAITO !
Thanks, Bill for the quick reply. I'm putting the 120 lite version together and the instruction manual must be for the older version, since a lot of the pictures don't quite match what I have. For instance, the throttle cable hole in the firewall won't even work where they show it should be. Did you use the rod that was supplied, or switch to a cable?
RFan
