RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Here's my lighting system for the cockpit I made from DBronk's ideas using yellow LED's, a resistor, micro toggle switch and a twin AA battery pack from Radio Shack for about ten bucks. I'm mounting the LED's in aluminum tubing to make the spotlights. The effect is good and the lights are the perfect brightness for inside the cockpit. Should look sharp. The LED's fit right inside the tubing which will be epoxied carefully to a ply mounting plate with the wires run out the sides, or bottom of the cockpit kit.
