Originally posted by m.gramling
Funflyer,
CG has nothing to do w/ how much power a motor has to pull out of a hover.
CG does a few things but power is not one of them. Moving the CG will make the plane more responsive, meaning rudder and elevator will be effect flight control, but you complained about not being able to pull out aggressively.
I know that, but my complaint was
"It's just that if the plane falls of the hover with full throttle it's not enough to pull in back on line."
It maybe that I don't have enough control authority to pull it back on line. When I fly straight and level and pull up it goes til it's a dot in the sky. The plane is a Diablotin.
