RCU Forums - View Single Post - MY KADET LT-40 BUILD
Old 10-25-2005 | 03:30 PM
  #62
shd3920
Default RE: MY KADET LT-40 BUILD
Bruce, my boy - not at all the reason for changing - I am just getting a little bit too picky now and I just prefer the nylon clip version over screwing it on through the top. Because it is actually two screws that support the clip http://www2.towerhobbies.com/cgi-bin...?&I=LXDMM0&P=0 it is actually gonna be a wee-bit heavier compared to only one screw through the top
I happened to have found a few of the clips laying around and decided to put them to use.
I have a question referring to my color design I posted earlier - I am keeping it because I love the look - but I have to know if the way to do it is correct. I will post a 3-way graph later displaying how I believe the order of covering sequence should be in reference to how the different color seams should match up. I am working on the graphics now on Microsoft Paint and will post soon.
After checking and rechecking the alignment, all parts (MADB braces, spars and W1 ribs) were coated with 30-minute epoxy, slide in place and clamped together to dry.
After a couple hours I will unclamp the whole shebang and reglue all the points that need it and do some filling in of gaps if necessary.
Posted is a pic of the dried fuselage halves ready to be assembled.
