The lightest system around is pull-pull by far, especially if you use Kevlar cables which I recommend. It also offers full adjustability such that you may produce exact output from one elevator servo. Set-up is simpler than most other set-ups. Never scimp on clevises: use ball bearing types all around.
MattK
ORIGINAL: patternflyer1
Thank you both for taking the time. I appreciate it.
I'm building a C.A Eclipse and going the Axi F3A electric route. I'm trying to save any weight that I can anywhere.
I do have the mk bellcrank in my other ship but I didn't know how much it weighs. I was thinking of the bellcrank of the DEPS that Central sells.
Thanks alot!!!!!!!
Chris
