RE: Anyone converted 4-cycle gas string trimmer?
How does your engine mount work out? Mine was a real shaker but I think it had to do with the rigidity of the mount. I'm in the process of turning the fins off the flywheel but the belt on my lathe broke. I'm planning to check the balance of the flywheel when I'm done. If you do a search for my login name mgnostic you should be able to find a pic of my four stroke project
