RE: Brison 3.2 Backfire.... HELP!
Naw, you have air coming into the engine compartment and changing the pressure around the diaphram. There is a couple of things to do. RCIGN can make you a plate with a nipple on it to run a fuel line back inside the fuselage. You can also make a baffle so that the air around the carb diaphram is still. This will address your problem.
