RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 10-26-2005 | 01:37 PM
  #3564
The MacDaddy's Avatar
The MacDaddy
My Feedback: (10)
Default RE: U-Can-Do 3d 46?
I would run a couple of tanks on the ground and reset the hi/lo needles, digi tach is helpful too. check your plug, I run OS F's. The Wildcat Curtis Youngblood is $15 a gallon here at the LHS, reason is, it runs way too hot in heli engines, I have a Rappy 50 w/ an OS 50 Hyper, CY runs 20 deg hotter, not good. I still run Coolpower Heli in my Rap. That is why the CY is so cheap, if you wondered. Like I said, make sure you have great air flow and run rich.
