RE: BME 110 Ignition Problem
I had the same problem and confirmed it with the troubleshooting procedures on the CH website. Ordered another sensor from CH and it burned out within 5 flights. CH sent another one that had an extra ground wire. Haven't had a problem since then.
Make sure you check the timing after replacing the sensor, mine was off by over 3 degrees.
