RCU Forums - View Single Post - OFFICIAL KYOSHO MP777-SP1/SP2 THREAD
Old 10-26-2005 | 06:41 PM
J_Bone's Avatar
J_Bone
Default RE: OFFICIAL KYOSHO MP777-SP1/SP2 THREAD
My setup 777SP-2
front
50wt oil stock 1.4 piston
SP-2 blue spring
middle hole on SP-2 tower (inside on SP-1), inside hole for shock on arm
22 degree caster blocks, middle hole in blocks with long ball end and
short upper arm (IF329), 1.5 camber
Upper Block H & Low A block
std sway bar, flush end
ride height front bones just above level
5000K diff oil
steering in middle hole in rack
Full droop
Center
Stock spur
13 clutch bell
Kyosho stock 3 shoe clutch 1.0 springs
7000K
Rear
40 wt oil
std rear sway bar, flush
2 deg anti squat, 3 deg toe, 1.5 camber
hubs forward
camber link long and in lower hole in tower
inside hole in tower, inside hole in arm for the shock
SP-2 blue springs
bones level if bumpy just above level
3000K
Full droop
