RCU Forums - View Single Post - TF Contender
Thread: TF Contender
Old 10-27-2005 | 09:34 AM
  #34
OverTheEdge
Default RE: TF Contender
Mike,
Thanks for the compliments... You'll probably get a chance to fly yours before I get mine to the air field. My club just moved to a new field this year and the ground is still bumpy and I'm sure as the temp keeps dropping it'll get even bumpier... so I'll most likely have to wait 'til spring. But we'll just have to see.
Badger,
Did you use the sheeting that came with the kit or did you buy wider sheeting to eliminate the edge gluing??? Like the fuse... I'm thinking of tail mounting the elevator servo and puting pull pull on the rudder (beings my rudder is just a liiiiittle bit bigger than stock).
Safebet,
Instead of putting in dead weight (lead) how 'bout moving that elevator servo to the back by the horz. stab.???
Keith
