RE: Excelleron 90 build in progress
I have a couple of packs of those clevis's and used them in place of the stock ones, on the ailerons.
As far as the elevator and rudder are concerned, I am going to see what it looks like after I get the vert/horiz fins installed then I will look at the control surfaces to see how to make those work with the Sullivan coated kevlar line.
From what I saw, if installed correctly, the stock links should work and keep alignment with the hinge line intact. But, again, I have not looked that closely to see how it is. Will probably do that this weekend, if the weather turns crappy.
DS.
