RCU Forums - View Single Post - MY KADET LT-40 BUILD
Old 10-27-2005 | 12:26 PM
  #75
shd3920
Default RE: MY KADET LT-40 BUILD
ORIGINAL: bubbagates
ORIGINAL: bruce88123
Good progress. Yep, don't glue the clamps to the plane. Too heavy!
Also very difficult to cover
Not only that but doesn't go with my color scheme and doesn't balance correctly unless I glue another clamp to the other side of the fuselage
That is why I HATE USING CA GLUES. But seeing as though the fuselage can only be glued after assembly and aligning I needed and it instructed to use a glue that wicks into the wood. If I only used Titebond II it would not have wicked into the parts and would have been weaker. I have just recently reglued all the joints with Titebond II for added strength. Will post that progress later.
