ORIGINAL: proulxlaw
The control throws are/were all at the recommended settings. Again, CMP is in the best position to give the consumer the correct information. It is simply irresponsible for them to promulgate information especially information as critical as CG without conducting extensive testing to insure its' accuracy.
Yours flies great and sounds awesome. I should have just bought that one. I have a new YS 120AC that I could have thrown in it too.
Mine has a YS 120 NC. Your AC will work great.
For reference, my CMP Zero 120's CG is 145 mm. Assuming the proportions are the same, the Zero 50's CG @ 95 mm does not sound out of place. Maybe their Zero 50 is just a squirly flier even at correct CG. I heard their smaller P-40 Warhawk flies pretty bad. The larger one, however, I haven't heard a flight report.
