RE: Excelleron 90 build in progress
Gordy: Did you seal the hinge line like they say in the book? I didn't use the nylon pin hinges that came with the model, I used CA hinges instead. The gap is pretty small.
I've never used the fuel dots, just the standard tubing. Not sure exactly how they work, although I guess if I looked at it I could figure it out easy enough.
DS.
