RCU Forums - View Single Post - MY KADET LT-40 BUILD
Old 10-28-2005 | 07:21 AM
  #82
bruce88123
Default RE: MY KADET LT-40 BUILD
Don't run the wire that way. Once you glue down the mount, how would you ever change/remove the servo? Servos occasionally need to be removed. Just make a litte natch along side the servo body that the wire can snake out of. I am assuming that you planned to glue down the mount plate.
I forget what color you need, will any of these work OK?
http://www2.towerhobbies.com/cgi-bin...nt&FVPROFIL=++
There may be others available from other dealers.
