RCU Forums - View Single Post - Is the h9 extra 260 pattern capable?
Old 10-28-2005 | 08:39 AM
MikeEast's Avatar
MikeEast
Default RE: Is the h9 extra 260 pattern capable?
Sure it can,,, at least to some extent... If you are talking about the 33% its too big to make the size/weight limit but you can certainly fly the patterns with it.
I fly the patterns with my big gasser all the time.
The point to pattern is learning to fly
straight lines at a constant distance out parallel to the runway (unless its a correcting turnaround at the end of the box)
Rolls in the middle of a straight line
constant, consistant roll rates.
symmetrical geometric maneuvers (round loops, square squares,)
equal radii within a maneuver
You can certainly practice all of that with your plane and you will be better for it, but unless it falls within the 11# 2M its too big, except maybe for sportsman....
