RE: Excelleron 90 build in progress
Once I have the plane in the air, I will report back if the tape hinge holds up.
Since the tape hinge goes on so easy, I sealed the gap on all control surfaces including the rudder and elevator. I used to seal the gap with monokote as well, but the tap hinge is a lot easier to do, I just hope it will hold up over time.
Kevin
